Make Bruins Great Again
Por_sha911's Avatar
Question Is this bodywork repair OK?
My car has a B&B system. The bodyshop replaced the rear valance. Notice how it is touching the muffler:
This is what it looked like before the repair:
Question: is this OK or do I need to have the valance moved away from the muffler? (I'm thinking that the heat coming off the exhaust can't be good for the paint)
Joe
Old 04-07-2007, 09:22 AM
Zef Zef is offline
THE IRONMAN
Zef's Avatar
It can't be good for the paint and for the valence material (warping)...I thing the valence is supposed to have a heat shield installed there...
1984 911 CARRERA RUBY RED TARGA
SW CHIPPED-BURSCH CATBYPASS
MONTY FREE FLOW EXHAUST
<IN GAS WE TRUST>
Old 04-07-2007, 09:32 AM
the the is offline
That's not ok.
In addition to the heat, the engine/trans/exhaust assembly is soft mounted and moves around. The valance does not. Very ghetto to have the two rubbing against each other.
Old 04-07-2007, 09:33 AM
Por_sha911's Avatar
OK, now that my concerns have been confirmed, is this and easy fix or do I need to have the shop do it?
Joe
Old 04-07-2007, 09:41 AM
Nine9six's Avatar
Joe,
If the shop F'ed it up, then they should fix it; pronto, and without any grief, if they are a good shop.
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 04-07-2007, 01:14 PM
Jeff Alton's Avatar
What exactly did they fix, and why? Was the car hit in the rear? I doubt the solution lies in moving the motor or exhaust........
Have the shop fix it, they got paid to do it right.
Cheers
www.turn3autosport.com
Old 04-07-2007, 01:48 PM
Joe,
It looks to me like a completely different type of valence. Your old one has a "lip" at the bottom that flares out a little, while the new one has a lip that steps in toward the muffler. Is this the case because it's kind of hard to tell for certain from the photos? Did you intend a change of valence? +1 to Jeff's question.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 04-07-2007, 06:29 PM
Jeff Alton's Avatar
Ossiblue has a keen eye, I had not caught that. But it appears the parts are quite different. The solution may be in the parts.
Cheers
Old 04-07-2007, 06:35 PM
Need to fix ASAP. The valance will warp, the paint will burn and the entire engine bay will over heat. You need a heat shield and room for the heat to flow away about an inch between the muffler and valance.
Old 04-07-2007, 06:50 PM
Kevin Stewart's Avatar
it probably vibrates and rattles like heck, Kevin
Old 04-07-2007, 09:43 PM
Not Quite Banned
Thomas Owen's Avatar
The replacement is the wrong valance for your car -
Thomas Owen
1972 911T
1972 911S
Old 04-08-2007, 04:09 AM
