d S coupe
Guest
Posts: n/a
Oil pressure fluctuation
I have removed the engine of my porsche ( 2.7l) to repaint the engine and change the hoses. When driving the car, I noticed that the oil pressure dropped at about 3000 rpm. could it be the oil pressure sender that is defective? If so, where is it located on the engine? Is it the litle swich on the rigth side of the fan? Thanks in advance.
Daniel
Old 01-21-2001, 03:39 AM
mackgoo
Guest
Posts: n/a
The pressure switch is at the fly wheel end of the engine by a small cover that connects the breather hose to your oil tank.
Old 01-21-2001, 08:39 AM
Superman
Guest
Posts: n/a
While the pressure switch is at the rear of the motor (close to the tranny) and hard to get at, the sender that runs your gauge is on the front (near the rear bumper) of the engine and much easier to access. Mine looks just a little smaller than one of those (little weenie) Vienna Sausage cans. Check the electrical connections!!
'83 SC
Old 01-21-2001, 12:37 PM
d S coupe
Guest
Posts: n/a
Thanks for the help.
Daniel
[This message has been edited by d S coupe (edited 01-21-2001).]
Old 01-21-2001, 01:01 PM
