-   -   brake/reverse light dont work (http://forums.pelicanparts.com/porsche-911-technical-forum/340253-brake-reverse-light-dont-work.html)
supercarrera82 04-08-2007 10:16 PM
From the moment I bought this car the brake/reverse lights did not work. All I have done is check the bulbs to see if they are good, and they are. From anybody's experience where would I start to see where the problem is?? any ideas??
kbruz 04-08-2007 10:49 PM
What year is your car? Depending on the year, the brake lights are triggered by two pressure sensors on the master cylinder. Not too sure about the reverse lights. Did you check the fuses?
Dan in Pasadena 04-08-2007 10:50 PM
Fuses, backup switch on trans and brake light pressure switches. After that get a simple continuity test light and a partner and track down where you loose your electric charge.
supercarrera82 04-08-2007 11:01 PM
my car is a 1982 porsche 911 sc
kimlangley7 04-09-2007 05:16 AM
Had a similar problem with my 80 SC
Could be the backup light switch located on transmission > gain access via the transmission access hatch on rear floorboard... It's a tight fit..
I think the part/switch was $45 or so...
