Question Drivers door lock linkage
Guru assistance needed!
I am rebuilding my door panels, replacing speakers, door handle & flag mirror seal, etc. Once I re-assembled the door handles the locking linkage quit functioning. I am not sure where the issue is and it's difficult to inspect the linkage inside the door.
Is there a trick to this activity???
Comments please.
Thanks,
Jeff
Targa4now
1981 911SC Targa
Old 04-08-2007, 08:42 AM
Jip Jip is offline
If you removed the door handle,maybe,,just maybe the 'dog' on the door handle isn't in the center of the locking mechanism. Did you disassemble the door handle? If so,you can get that and the locking mechanism all 'farkled' up. It takes a bit of study but I'm sure you figure it out.
"Cheers" Roadslayer
'70 pickup
And 2 cats
Old 04-09-2007, 11:28 AM
gestalt1's Avatar
roadslayer is right, the lever pin on the back of the handle needs to be between the arms of the "Y" part on the latch. if it isn't it will keep the latch from locking. i know this by making the same mistake a few times.
-matt
BMW 128i
73 rsr clone - sold
68 912 project to become 911r (almost done!)
Old 04-09-2007, 11:50 AM
Thanks Guys.
I did not rebuild the door handle. I was more concerned with the seals on the outside and opening and closing the door that the locking linkage. Time to purchase the telescoping mirror!
Thanks for your advice.
Jeff
______________________
Targa4now
1981 911SC Targa
Old 04-10-2007, 07:27 AM
Jip Jip is offline
Actually,you should be able to see up in there with a flashlight. You do have the door panel removed.Right? It's a pretty simple mechanism once you see how it works. Only took me aboout 15 times to get it right.
"Cheers" Roadslayer
Old 04-10-2007, 07:58 AM
