-   -   I know this is stupid, but I need to spend $3.75. (http://forums.pelicanparts.com/porsche-911-technical-forum/340482-i-know-stupid-but-i-need-spend-3-75-a.html)
Zeke 04-10-2007 08:38 AM
I built a small order at Pelican and they say $3.75 more for free shipping. I can't think of anything I need. I suppose I can always buy another oil filter, but I thought your suggestions might come up with something cool.
Zeke 04-10-2007 08:43 AM
BTW, this is highly technical stuff, so don't move it.
petrolblue83911 04-10-2007 08:48 AM
new drain plug/washer?-not cool but usefull at times..
berettafan 04-10-2007 08:53 AM
I need 6 manifold to head intake gaskets. I'd be happy to pay you for the gaskets and shipping to me if it saves you a few bucks.
304065 04-10-2007 08:55 AM
Man, you can ALWAYS use more aluminum crush washers or CV joint gaskets.
masraum 04-10-2007 08:56 AM
How about a T-shirt, poster, book?
Maybe some ATE blue?
the rubber hoses for the heater
The "L" or "T" valves for the windshield washer
fuses? relays?
Eric-325I 04-10-2007 09:05 AM
Buy yourself a small treat... Pin
Eric
DCinVA 04-10-2007 09:10 AM
OK here are a few suggestions.
Any annual maint items like
Wiper blades
Fuel Filter
oil filter
Air Filter
Spare Fuses
How about new door light switch rubber caps. $2.75 each
901-615-616-20-M260
pwd72s 04-10-2007 10:38 AM
Spare bulbs? Everything from headlights to dash? They all need replacing sooner or later. (edit) That would run more...but you can start with the ones a cop might pull you over for if non functioning. "The reason I stopped you Millner, is that the license plate light is out..." ;)
wesayso 04-10-2007 11:23 AM
a cool collar for your oilfilter?
rnln 04-10-2007 11:25 AM
milt,
an oil filter is something you always have good use of.
Porsche_monkey 04-10-2007 11:38 AM
Curil-T. I always run out of it. Can't find it anywhere else.
randywebb 04-10-2007 11:42 AM
buy some of the fancy brake lube paste and then ship it to me
arcsine 04-10-2007 11:43 AM
need a spare relay ?
azasadny 04-10-2007 11:50 AM
Fan belt
Zeke 04-10-2007 11:50 AM
Shoot, if you're in Maryland, you're probably just as well off to order direct. Thanks for the thought, though.
Well, I'm not so much for the stick pin or tie pin, but if that's the best cool thing we can think of (other than a cool collar, I mean how much cooler can you get?)....
Zef 04-10-2007 11:57 AM
Originally posted by azasadny
Fan belt
+1 for fan belt...!
Porsche_monkey 04-10-2007 12:04 PM
http://www.pelicanparts.com/catalog/shopcart/STUF/POR_STUF_ATNEON_pg10.htm#29
Zeke 04-10-2007 12:19 PM
OK, OK, I ordered some spark plugs. I looked on the shelf and in the car and I had everything else suggested as a practical item. So, I dropped another dime on our host. ;)
It's easy to spend money, huh. :D
tt_targa 04-10-2007 12:22 PM
How about a nice key blank.
At $13.75, it's a little more expensive but nice to have an original spare.
