front wheel bearing check
I seem to remember from way back when that to check the front wheel bearings, I should raise the car and push/pull on the top and bottom (12 oclock and 6 oclock) of the wheel, tire. When I do this, there is some slight movement and noise. If I push/pull on the sides (9 oclock and 3 oclock), I feel no movement or hear any noise. Do I need to:
Check and tighten the wheel nut or
remove, clean, and repack the bearings, or
replace the bearings?
Thanks in advance,
Rob
356robo
70 T Targa
Looking for a 2.2,2.4, or 89 coupe
Old 04-10-2007, 05:54 PM
randywebb's Avatar
no
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 04-10-2007, 06:02 PM
I think you should at least see where you are with adjustment first. Remove the dust cap, which may not be easy but search for tips on removal. Get a flat head screw driver and move the washer between the nut and bearing. You should be able to move it with moderate resistance. If it moves easily, I would take the bearing out, clean it well and look for excessive wear. Re-pack, reinstall to the point where the washer is snug but moveable. Do your 12-6 and 3-9 wiggle checks. If it feels good, button it up and drive. If the bearings have not been replaced for several years, might be a good time to just put fresh ones in.
If you track or AX the car. I would say new bearings would be in order.
Use good synthetic wheel bearing grease as well; Redline or similar.
Tony G
2000 Boxster S
Old 04-10-2007, 06:05 PM
