rnln's Avatar
Full gas tank makes the car drive better
How much a full tank of gas weight? Every time filling full tank of gas, my car drive better. I am not sure how to describe it but I just feel like it more, like to gun it. I feel it's more stable. Is it the pressure increase make the car run better? Or is it the weight in the front make the car more stable? Do you guys feel the same or it is just my imagination after spending the $$ feeding the car?
My car is very lowed and harsh.
Fat butt 911, 1987
Old 04-10-2007, 07:35 PM
pjv911's Avatar
Send a message via AIM to pjv911
It makes sense since the weight bias is better balanced. Could also be that your front end alignment is set to favor a full tank. Relize the camber and toe change as the suspension compresses.
I find the same thing with my SC which has a 21 gal tank and a heavy g50 tranny and a 965 turbo engine tugging down the rear. A full tank kinda improves the road feel for routine traffic use.
On the other hand thats the only 911 I have that feels more stable with the full tank. The rest of them clearly show a sluggish change in steering responce when topped off.
Kurt Williams
Never drive faster than your gaurdian angel can fly.
82 SC w/965S eng and G50 6:1 hp/w ratio
72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles
65/66 912 1 owner 76k orig
01' Aston Martin DB7 V12 Vantage Coupe 6spd
Old 04-10-2007, 07:45 PM
ttweed's Avatar
Re: Full gas tank makes the car drive better
Gasoline weighs around 6 lbs./gallon, so an addition of 20 gallons to the tank will add about 120 lbs. to the front end.
TT
Tom Tweed
Early S Registry #257
R Gruppe #232
Rennlist Founding Member #990416-1164
Driving Porsches since 1964
Old 04-11-2007, 06:20 AM
Tired Member
DaddyGlenn's Avatar
You will also find that a full tank reduces front end float at extra-legal speeds.
Glenn
Daily Driver - '78 911SC RoW
Endurance Racer - '85.1 944
Street/Track Project - '86 951
Race Project - 944 Spec
Old 04-11-2007, 06:43 AM
vash's Avatar
it is because your wallet is so much lighter......
poof! gone
Old 04-11-2007, 06:56 AM
rnln's Avatar
Now the thought is if I can have this feeling even when the tank is almost empty with some harder struts up front?
Fat butt 911, 1987
Old 04-11-2007, 11:46 AM
I keep the tank full on my SC--refilling when it's down a quarter tank. In normal road driving, I don't notice any effects of weight distribution--very stable handling.
My old Corvair was much more front end sensitive. Loading the front trunk up helped a bit, but it was a different feel. A different class of car in terms of handling.
'03 Boxster *****
'82 911SC ****
'98 BMW Z3 **
'87 300Z ***
'80 BMW 320i ****
Old 04-11-2007, 04:28 PM
