Eye of the Toiger
ssi 2in/out on an 89 3.2 euro
Can I put my ssi's 2in/out on an 89 3.2 euro motor if so what' involved?
http://www.aircooled.com.au 1973 911 RSR clone powered by 77 3.0 turbo |
Information Junky
Thick or thin flanged?
O2 sensor provision on the SSi's
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2˘ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
Eye of the Toiger
Not sure how do I tell, They are on my 2.7 at the moment not sure is there is a O2 sensor provision where will i find it?
matt
Information Junky
If they are on the 2.7 they are likely thin flanged --the 3.2 likely has longer studs for thick flanged. (not too big of an issue)
On the O2 . ..your set likely doesn't have it. If you want to look it exists on the left side SSi. --it would be a blocked-off threaded hole if it is there...as a 2.7 doesnt use an O2 sensor. hope that helps. for pictures and/or more info, try the search above.
island is right. no issues just have to use spacer to take up the distance on the threaded stud. .
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
Friend of Warren
SSI's on 3.2 engine:
Kurt V No more Porsches, but a revolving number of motorcycles. |
Information Junky
One other issue, to check out, is the flange lead-in. (the 3.2 has bigger exhaust ports) Check out this thread (click)
....and specifically: Quote:
Here's mine with a m&k.
75 911 Indian Red- RUFWAN2B 2000 Boxster 2000 & 2007 Dobies www.stahlwerks.com Cages and preparation for your Porsche “People who never make mistakes must get tired of doing nothing” Bill : The origin of the orgy of Porsche |
Eye of the Toiger
where can I get the spacers
Also if it does not have an 02 sensor what needs to be done to accomidate this? I have an M&K 2in /out exhast as well
Eye of the Toiger
Duke Zink,
where did you get the air filter for the 3.2 ? Matt
It's just a K&N with a 3 1/2" flange. Note I'm not using the AFM because I'm running megasquirt.
spacers can be washers or machined spacers. I bought 503 rotax head stud spacers for the shroud. works perfect
Eye of the Toiger
mb911
where can I but the 503 rotax head stud spacers?
LEAF= Leading Edge-Air Foils .com 800-532-3462 ask for Jack or Brian.
