(the shotguns)
What does 'detonation' sound like?
Pookies recent post looking for diagnosis got me wondering what 'detonation' sounds like. My 911 is the first car i've owned in a LONG time that doesn't think for itself in that regard and i realized i have no idea what the bad sounds are.
Could anyone post up some vid/sound files of various maladies along with a description of what we're hearing? might be a nice sticky.
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
Monkey Butt Forespin
Well from what I've read about the 911... if you really can hear it, it sounds like money leaving your wallet at about the speed of light.
Fred Hurder Jr For Tech Questions: '84 911 Carrera Cabriolet (US) Weltmeister Chip, Fabspeed Euro Pre-Muffler, M&K 1-in / 1-out Muffler 22 ERP /29 Sander Hollow T-Bars, Bilstein HD Struts / Sport Shocks ERP Poly-Bronze Bearings (A-Arms & Spring Plates), Stock Swaybars Turbo Tie Rods, '92 C2 5-Spoke wheels w/ 1" adapters, Drilled Zimmermans Yes, I drive mine as much as possible. If it's >32° & sunny, I've got the top down.
Registered Usurper
Detonation is not always audible. When it is, it can sound like spraying BBs into a tin can. Whether inaudible or audible, it's sure destructive (e.g., can burn holes through the tops of pistons in very short time).
'82 SC RoW coupe |
abit off center
I was going to say a real fast rattle sound...like the BB's in a can, yep.
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Sub-audible detonation breaks rings just as well as the kind you hear.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
I've heard it as spark knock (too much timing advance) at lower engine speeds - sounds like a pinging sound, sort of like hitting a metallic object lightly with a rock or shooting a glass bottle with a bb gun without breaking the bottle.
I've heard it as autoignition in an 11:1 compression V8 (my long gone 1969 Ford LTD with a 429 engine - I still miss it) refusing to shut off on a hot day because I ran out of tetraethyl lead mix to add to the 94 octane Sunoco gas I put in it. Sounded like somebody banging the engine block with a ball peen hammer as hard as possible. And +1 on the stuff you can't hear ...
'88 Coupe Lagoon Green "D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen" "We must not allow a Mineshaft Gap!" |
