-   -   Vent System and Heater - Deleting What I Don't Need, Keeping the Defrost (http://forums.pelicanparts.com/porsche-911-technical-forum/341255-vent-system-heater-deleting-what-i-dont-need-keeping-defrost.html)
Ove 04-14-2007 02:18 PM
I removed the heavy engine compartment blower a long time ago and decided it was time to loose some weight from the front end as well. First I removed the stock parts:
http://forums.pelicanparts.com/uploa...1176583745.jpg
I need defrost for driving in the winter and also for when it rains. So I knew I had to get hot air to the defroster outlets. I also wanted the possibility of getting heat down at my feet.
I purchased 2 vents, 2 Y-shaped pieces and an heater hose at a local boat supply store. The hose and all inlets/outlets are 60mm. This is what it looks like now:
http://forums.pelicanparts.com/uploa...1176585112.jpg
The pictures below show how I made and mounted the parts. Lifting/pulling down the handles next to the hand brake turns the heat on/off. I keep the footwell vents closed for max defrost.
Here's my old thread with more info on the heating system.
http://forums.pelicanparts.com/showthread.php?s=&threadid=332435&highlight=altern ative+heater
http://forums.pelicanparts.com/uploa...1176585282.jpg http://forums.pelicanparts.com/uploa...1176585306.jpg
http://forums.pelicanparts.com/uploa...1176585345.jpg
Ove 04-14-2007 02:22 PM
.http://forums.pelicanparts.com/uploa...1176585618.jpg
http://forums.pelicanparts.com/uploa...1176585642.jpg
http://forums.pelicanparts.com/uploa...1176585665.jpg
http://forums.pelicanparts.com/uploa...1176585701.jpg
Ove 04-14-2007 02:31 PM
I have a pair of footwell blowers and will install them before the next winter. I made a new aluminum panel with push/pull switches to turn the blowers on/off.
http://forums.pelicanparts.com/uploa...1176585802.jpg
http://forums.pelicanparts.com/uploa...1176585823.jpg
What remains to be done is to make and install a small airbox behind the stock air intake. I also want to make a large aluminum panel to cover the entire glove box/radio/vent control area.
k9handler 04-15-2007 04:45 AM
very cool (um warm) project, seems like it would work pretty well as long as rpms are up.
bigchillcar 04-15-2007 06:08 AM
nice ingenuity, ove! :) looks like great work, too.
k9handler 04-15-2007 07:09 AM
so does the old defroster motor work? I need one as mine is broke.
Kroggers 04-15-2007 12:10 PM
Looking good Ove :)
bigchillcar 04-15-2007 03:32 PM
you don't need no dang defroster, smit....you KNOW what you need a little more of!
:D
Ove 04-15-2007 03:57 PM
Yes it did work when I removed it. But it was a bit noisy. Would recommend getting one in better condition than mine.
cshaffer 02-16-2009 06:22 PM
Ove,
Great idea, how much did the removed parts weigh?
Ove 02-17-2009 03:10 PM
Originally Posted by cshaffer (Post 4490034)
Ove,
Sorry, I don't know yet. I didn't have a scale around when I removed the stock vent system. I still have all the parts though and will post their weight later.
After driving the car in the winter I can add that the heater is not very efficient. Not a big surprise.. But once the engine reaches normal operating temperature it works ok. I'm going to use a small additional blower (footwell blower).
http://forums.pelicanparts.com/uploa...1234912143.jpg
http://forums.pelicanparts.com/uploa...1234912076.jpg
