numbers
Hi Shaun ..I have the same plate what I could find out was that one of the two sets of numbers have to do with baking temp of the paint but I could not figure out what the color was,,, My car is black and I have looked in every crevice to find a different color with no luck....please let me know if you find anything out? here's the picture of my platehttp://forums.pelicanparts.com/uploa...1418375976.jpg
Ask Porsche. They built the car.
My educated guess is that the upper line refers to the silver paint, with supplier Herberts
The lower line probably refers to the clearcoat; this was a metallic paint with a clearcoat top layer. |
119111254 76 81 9101 H & 77 94 0503
119200437 76 81 9101 H & 77 94 0503 119200478 67 81 9101 H & 77 94 0503 119200873 76 81 9101 H & 77 94 0503 119300618 76 81 9101 H & 77 94 0503 newest 119300864 76 81 9101 H & 77 94 0503 new 119301483 76 81 9101 H & 77 94 0503 new 119310372 76 81 9101 H & 77 94 0503 129000363 76 81 9101 H & 77 94 0503 129010359 67 81 9101 H & 77 94 0503 Theodore69 76 81 9101 H & 77 94 0503 |
Here is the newest photo; best yet.
http://forums.pelicanparts.com/uploa...1483670924.jpg |
picture of my car paint codes
Another one added today: 119300864 76 81 9101 H & 77 94 0503
Just bought 1969 911S #119300864 http://forums.pelicanparts.com/uploa...1492687594.jpg |
Well, thanks to Ron Cavallo for this photo of original paint cans we now have proof positive of the correct paint code and the meaning of the two rows of numbers. This confirms the upper line as the silver paint code, and the lower line as the clearcoat. Ron writes: "My car came with extra paint when I bought it new. The can of silver has a code that ends in 9101H and the can of clear coat ends in 0503. There are lead numbers on the cans, 67-81 for silver and 77-94, on the clear coat."
http://forums.pelicanparts.com/uploa...1492777077.jpg |
Wow! 10 years and a week!
Wow indeed. That is very cool that this mystery appears to be solved. :)
Was silver the only color offered with base/clear coat? Wouldn't there be other colors (and double-row numbers) also out there?
Wow! Here I thought my Gemini Blue Metallic 75 was a base coat, clear coat car. I guess this means it was not, since it only has the Gemini Blue Metallic paint code line on the A-Pillar tag?
This forums is amazing. Actually old paint cans? Really! Amazing! |
I'm not saying that there were no other base-coat/clear-coat, just that the 1969 silver is the only one I know of with a two line paint code. The 1969 silver was a very unique situation. I am sure that most other metallics were base/clear, but I do not know if that extends back into the 1950's.
BAM! And just like my 11 year-old question was answered
By this thread. I have a silver metallic 1969 912. The COA says the color code is 6851. But the door plate has the familiar numbers:
76-81-09101 -H 77-94-0503 I had wondered if someone put their own codes on the car. The door plate is native Porsche for 1969. Thanks. Scotthttp://forums.pelicanparts.com/uploa...1508276917.jpg |
Hello Scott. Glad that we have helped. Can you PM me your VIN to add to my database please. I am trying to track the use of the two code versions.
Dave |
this thread is amazing!
I just found a 69 911E (2.0) with the infamous double digit code The vin of the car is: 119200781 It's an 69 911E with the 2.0 engine https://www.oldspeed.net/images_voit...lor%20code.jpg The car was repainted in a blue shade however William |
69S...
http://forums.pelicanparts.com/uploa...1604934405.jpg Anyone have a formula to mix this paint? Because I'm bidding on a restoration of a very molested example with no remaining silver, whatsoever. |
As mentioned early in this thread, the earlier versions of these silvers had discoloration issues, turning a slightly brassy color over time. The issue was finally remedied with the change to 936 partway through the '72 MY. What I found was that many paint catalogs no longer have formulas for the earlier codes, just the final iteration (936). Glasurit also had (as of mid-2019) a formula for the prior code (925 as used on my car, and through Sept. '71), but the formula was exactly the same as for 936. From this hint, I came to the conclusion that the actual formulas for Porsche silver when using modern paint that won't discolor later are pretty much all the same. It was a bright silver with very fine grain metallic flakes. I'm pretty sure that if you used any of today's high quality paints that have formulas for either 925 or 936 you'll be fine. http://forums.pelicanparts.com/uploa...1604941744.jpg https://www.early911sregistry.org/fo...2&d=1573872928 |
| All times are GMT -8. The time now is 11:47 AM. |
