-   -   Another G50 noise thread. Advice? (http://forums.pelicanparts.com/porsche-911-technical-forum/341372-another-g50-noise-thread-advice.html)
Jean Berk 04-15-2007 10:29 AM
Ok - I get a fairly loud whine on deceleration, even louder if it's downhill. It seems worse after warm-up.
I had the box stripped down and all bearings were replaced except a mainshaft bearing which was left in because it was concealed between two of the gearbox castings - stupid I know - it should have been done.
So - could that be the culprit? I wonder if it might be the diff ring & pinion?
Any other suggestions guys?
