Mark Wilson
Guest
Posts: n/a
Help ID wires for 6 pin CD connector
The harness has been hacked and I'm trying to confirm the correct connections for the wires and ID the red one. Is it a switched 12V power in to the CD box? Are all my other labels correct? The engine is a '80 3.0 and car is a 70 T. Thanks
Old 04-15-2007, 06:10 PM
Mark Wilson
Guest
Posts: n/a
The 123456 are in the order on the plug.
Old 04-16-2007, 06:55 AM
I would rather be driving
jpnovak's Avatar
Mark,
You have them correct. You can verify using the designations on the side of the unit.
Old 04-16-2007, 07:27 AM
Somatic Negative Optimist
Gunter's Avatar
Hmm.........not only does it look hacked, it looks fried.
Checking the SC-Bentley 280-9, your plug could be right depending which is top or bottom.
Meaning: 1 & 4 could be where 3 & 6 is.
The home-made wire 1 & 4 in your picture should be the proper coax signal wire from the distributor given as #7 and #31d on the Bosch CDI module.
2 & 5 are Power and Tach signal (#15 and TD Bosch)
#15 gets power from fuse #22 with OEM wiring.
3 & 6 are pos. side coil and ground (A and 31/1 Bosch)
The OEM Bosch plug can only be installed one way to prevent accidental switching.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 04-16-2007, 09:14 AM
Mark Wilson
Guest
Posts: n/a
Thanks Guys. The connector has the numbers on it in the order on the picture. The white coax runs out to a connector about 6" from the distributor, then goes to green on the other side of connector to the distributor.
Jamie, I took your advice and pulled the wiring off the 2.2 and split it. That harness wan in much better condition. For now, I can use the 6 pin from the 3.0.
Old 04-16-2007, 10:14 AM
fred cook's Avatar
Cool 6 pin info............
On my SC the wiring is as follows. Looking down on the wiring harness plug with the bevel edges towards you they are:
1. front left = system ground
2. front middle = tachometer signal
3. front right = signal ground (green wire shield)
4. back left = coil hot +12 volts
5. back middle = switched +12 volts
6. back right = signal (green wire center connector)
Hope this helps!
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 04-16-2007, 06:03 PM
Mark Wilson
Guest
Posts: n/a
Thanks Fred
Old 04-16-2007, 07:36 PM
efhughes3's Avatar
Hey Mark, how's the rest of the "adoption" going?
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 04-17-2007, 05:34 PM
Mark Wilson
Guest
Posts: n/a
Ed - Evrything id in except wiring and axles. The CV's are clean and ready to grease up and reinstall. Wiring should about 4 hours to complete. Gas tank is in, shifter insalled and adjusted. I hope to light it this weekend.
Old 04-17-2007, 07:43 PM
efhughes3's Avatar
Good luck to you! I'm headed to Houston this weekend for the ALMS race, otherwise I'd like to come by and check it out.
BTW, I'm going in a different direction on the engine thing:
Ed Hughes
2015 981 Cayman GTS
Old 04-17-2007, 07:46 PM
Mark Wilson
Guest
Posts: n/a
What was the damage? Are you going 3.4?
Old 04-17-2007, 07:51 PM
efhughes3's Avatar
Some bent valves....the P's and C's look good, but will be checked for dimensional tolerance. Got a thread going on the build side..
Got my engine down to longblock status & got a bit of a surprize
Ed Hughes
2015 981 Cayman GTS
Old 04-17-2007, 08:17 PM
Early_S_Man's Avatar
Porsche Crest
Mark,
That looks like a Permatune conversion kit harness connector ...
Here is their tech/installation page:
http://www.permatune.com/T-ignition-Porsche-911SC.html
From their page:
1 = System ground == '31/1' . . . 4 = Coil + Hot (coil - to ground) == 'A'
2 = Tachometer signal == 'TD' . . . 5 = Power == '15'
3 = Signal ground, Green wire shield == 31d . . . 6 = Signal A) Green wire center conductor == '7'
For more Bosch 6-pin CDI info:
6-pin SC/Turbo CDI unit repair documentation
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 04-17-2007, 11:53 PM
Mark Wilson
Guest
Posts: n/a
Warren - thanks for the insight. That explains why the harness goesn't apper as stock. The post you linked to in the only one found with good info on the 6 pin. I appreciate all you guys guidance.
Mark
Old 04-18-2007, 04:09 AM
efhughes3's Avatar
"....and then the man saw the light at the end of the tunnel, and felt a great weight come off of his chest. And they all lived happily ever after, while driving great cars."
I could hear Mark screaming yippee when he got the post from Early S all the way over on my side of town.
Ed Hughes
2015 981 Cayman GTS
Old 04-18-2007, 06:00 AM
