You cannot troubleshoot a CDI system like a conventional system.
Don't hot-wire the coil in situ, it could damage the CDI module. Instead, do a search on how to test the coil outside the system, I remember several posts listing the values. Reconnect everything, use dielectric grease on the 14-pin plug etc. First, ensure that power goes to the module and there is ground. Ignition ON, pull the 3-pin plug off the module. Do you have 12V and ground? |
I have done a lot of trouble shooting and am still searching for an answer. I have started a new thread here.
Tom |
| All times are GMT -8. The time now is 12:21 PM. |
