I would like to delete the fenderwell mounted washer resevoir and replace it with a smaller resevoir/pump mounted in the trunk. Anyone done this lately and know of a tank that will fit?
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
Ferdinand Magazine
I got a later Carrera intensive washer bottle and put it in the SC - talk about easy, all the holes are there and the wiring/plumbing was a piece of cake. I've tidied up since this pic:
Sheriff at www.impactbumpers.com Brand support at classicretrofit.com/tuthillporsche.com 1976 Porsche 911 Carrera 3.0: 'The Orange' - 1981 924 Turbo - 1983 944 Lux - Too many BMW motorcycles |
Back in New England!
John,
What year model is that. I'd like to do this mod as well. Thanks, Matt
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip! |
Ferdinand Magazine
Reservoir: 911 628 027 00 Cap: 911 628 077 00 Pump: 431 955 651 Seal: 431 955 465B There is a hole pressed into the inner wing by the bonnet hinge that a part of the tank slots in to, check your car has that before you order. I will see if I can find a pic of what I mean.
Sheriff at www.impactbumpers.com Brand support at classicretrofit.com/tuthillporsche.com 1976 Porsche 911 Carrera 3.0: 'The Orange' - 1981 924 Turbo - 1983 944 Lux - Too many BMW motorcycles Last edited by johndglynn; 04-16-2007 at 03:46 PM.. |
Anybody parting out a (84-89) Carrera that has a windshield washer bottle and motor? I got real Yankee dollars to swap for one!
I used the stock pump and ran lines to a 1 liter aluminum bottle I placed in the smugglers box. No rewiring and mass centralization to boot
gary |
![]() The only problem is that the pump flows so much so fast you empty the tank surprisingly quickly (and often) if you fit new washer jets and spend about 90 minutes adjusting them.. In real life, you just get used to using a very brief tickle of the stalk.
'77 S with '78 930 power and a few other things. |
What did you guys do about the fuel expansion tank that was mounted on top of the washer bottle?
Silver 1980SC Euro coupe |
Ferdinand Magazine
Gary's cool aluminium bottle in the smugglers box was the catalyst for losing the big tank in the SC, I am putting it back on now though as the car is going up for sale, get the headlamp washers back working on there. I am doing the same thing in my C3 - losing the big tank. There is no space to do this intensive tank mod on that car though as the brake fluid reservoir is mounted in that spot, so I will probably put a plastic washer tank in the battery spot when I go to an Odyssey in the smugglers box.
Sheriff at www.impactbumpers.com Brand support at classicretrofit.com/tuthillporsche.com 1976 Porsche 911 Carrera 3.0: 'The Orange' - 1981 924 Turbo - 1983 944 Lux - Too many BMW motorcycles Last edited by johndglynn; 04-17-2007 at 07:04 AM.. |
coolcavaracing.com
Nice, will have to do the same
Pål (Paul) - The Norwegian lost in Finland... 1978 911SC 3.6 | 2001 Boxster S Racing Car | 1966 912 based 911 RSR replica racing car (for sale!) come and follow the Porsche Sports Cup racing fun and me at www.facebook.com/coolcavaracing
Thanks John.
In my street-licenced race car (which still needs to pass a safety inspection that requires a working windshield squirter), I used a plastic Nalgene bottle from REI, attached to the mount for the factory jack at the front of the trunk with a hose clamp. Drilled two holes in the lid for the tubes and done.
'82 911SC racecar '05 WRX STi |
This is great inspiration.
John, If you do have a pick of the slot/hole that is required, I'd love to see it. Thanks again, Matt
I went from this:
to this (was able to use an existing hole for mounting): just to be able to get some brake cooling hoses through to the brake disc from the bumper ( I use the oil cooler duct in the bumper): Just haven't got to the part where I do the connection yet .
Dennis Johansen PCS 3413 Porsche 911 SC -83 SCWDP member #0004 Saab 900 -88 Vinga Edition |
Dennis,
Are you going to put the fuel expansion tank back in? -Matt
![]() But I don't think this will be a big problem here in cold Sweden .
