Questions 3.2
I'm puting a 3.2 on an "R" replica and would like to use webbers for the retro look is a ROW 3.2 my questions are:
Would the webbers 40 work with bigger venturis it has 30 right now what cams should I use Would you just keep the engine original and use 964 cams Let me know your thoughts Thanks |
I guess my first question would be do you care about gas mileage? I think most run 46 mm PMO's on the 3.2 if they go that route.
| All times are GMT -8. The time now is 10:54 PM. |
