Erratic needle - Oil Press Sending Unit or the Gauge?
Recently, my oil pressure gauge needle has been making little variations or tiny 'bounces' and now is indicating a little lower than usual. Is this a Gauge problem or a sending unit problem?
Also, if I recall, it is either the oil temp sending unit or the oil pressure sending unit that is a b*tch to remove. Anyone done this? Otherwise the engine runs and sounds normal. Thanks...
Kurt |
Just took another look at it. It seems the AC bracket may have to come out of the way to get the sender out, still looks like a tight squeeze.
Kurt |
generally speaking, if the gauge moves, it's ok. the sender replacement requires removing the top of the A/C bracket. remove the sender and it's mounting block as a unit and clamp the block in a vise to separate the two.
FWIW: Mine bounces all over the place when revving/moving, too. At idle or cruising it remains steady. Not sure if this is a defect or SOP.
Okay,
Thanks, John
Kurt |
Band.
Make sure to clean all of the electrical connections too. Sometimes nothing is actually broken, just dirty.
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII |
First thing l'll try, clean up the connections then go from there
Kurt |
