Rennline Strut brace- 1 bar, 2 bar, or 3 point?
Which of these would you buy for a street car?
John Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance. |
You probably don't need either in a street car, but if you're gonna have a strut brace, you should also have monoballs, or you're sort of defeating the purpose. Here's the route I took as shown in this thread:
Strut brace model |
I have one in both my P-cars and I felt like it made a difference. Anyways, for a street car all you'd need is one bar. 2 or 3 bars would be overkill IMO.
Bill 997.2 |
Back in New England!
If you buy a one bar, you can always upgrade it later to a two or three bar. Rennline standardized its brackets for all three models (if you want to call them that)
I have a two-bar Rennline strut tower brace without monoballs and I've noticed a big difference during hard cornering. -Matt
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip! |
Wouldn't it be more noticeable on a non-"stiffly-sprung" street car?
I agree...
For coupes, doesn't make sense for street.
For targas and cabs, makes a big difference.
Tru6 Restoration & Design |
Hey go for the 3 point system.....Who cares if it doesn't do much when installed in a detailed front trunk it's worth the price just for the looks.......
'73 914 2.0, '74 911 Coupe, '74 911 Targa '78 924, '84 944, '86 944 Turbo, '84 911 Coupe '84 944 (current), '96 993 Coupe (current) '73 911T Coupe (current) '88 930S M505 (current) |
[QUOTE]Originally posted by kilodawg
[B]Hey go for the 3 point system.....Who cares if it doesn't do much when installed in a detailed front trunk it's worth the price just for the looks....... Mine looks better with the carpet in. :-)
Southern Class & Sass
Since it didn’t cost anymore, I bought the two-bar set up. I discovered the two-bar set up makes cranking in additional negative camber a bit harder. You have to crank on one bar some. Then crank on the other bar some. Then back to the first bar...
Dixie Bradenton, FL 2013 Camaro ZL1 |
Wow
I didn't know they were still making oil cooled 911s... Looks like new! |
The camera is a wonderful thing......Same lens used to film Doris Day.....
