Disconnect smog pump - 78 SC?
Have to keep the pump for emissions in Denver. Is it ok to take off the belt between emissions tests?
Any advantage to doing so?
Any disadvantage to doing so. Will I screw anything up?
Thank you.
Old 04-22-2007, 10:23 PM
Don't think you will have any problem. The pump forces air into the exhaust ports and there is a check valve in the hard line to the ports that prevents exhaust gases from flowing backward into the pump. It's located just above the engine tin on the left side, and it's where the rubber hose from the pump connects. Removing the drive belt simply shuts down the system of air injection.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 04-23-2007, 07:11 AM
TWork's Avatar
You can either just remove the belt, or remove the pump all together. Won't hurt.
'73 Targa
Old 04-23-2007, 08:34 AM
Mocha BAP
Staylo's Avatar
Send a message via Yahoo to Staylo
I would remove the entire pump and store it safely. They have been known to sieze up while left in place without the belt. Takes about 5 mins. to remove.
Scott
71 911T Coupe 3.0 Looks stock
79 911SC Coupe 3.2ss Nothing stock
02 996 C2 Cab Mostly stock
06 955 CTTS Super P!G
Old 04-23-2007, 10:23 AM
So, install and remove once a year? I could do that.
Old 04-23-2007, 11:26 AM
Registered abUser
TerryH's Avatar
That's what I do/did. Removed pump except for smogging. Too expensive to replace/repair old pump parts. When CA removed the 30 year rolling smog exemption, it forced many to have to cheat a little to survive the next 50+ years with old outdated, but mandatory, smog equipment.
You may run slightly rich without the pump working.
'81 911SC Coupe SOLD
Old 04-23-2007, 11:48 AM
