khamul02's Avatar
strange sticky gas pedal
Strange thing. My 80SC has sat for about 2 months now with a weekly cranking. I take it out today and the gas pedal or something... sticks. I'm not sure what is going on.. here is what happened twice.
When driving and keeping the RPM under 5 K nothing irregular.
If I pushed it over 5 K for just a second and released the clutch to change gears the car revved to MAX... well past the red line... It is like I was flooring it..
I just did a quick check to make sure nothing was holding the pedal down such as the carpet. Nothing appeared to be. I haven't looked into it any more.. Any advice before I start troubleshooting?
Tom Hutchinson
80 Targa / 81 Coupe / 71 Targa (in Porsche heaven)
My Garage Build: https://youtu.be/H0n_NwEQVbs
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
Old 02-02-2010, 07:58 PM
just me
paulgtr's Avatar
Send a message via Yahoo to paulgtr
how high did it rev?
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses.
http://www.hairydoggrrrage.com/
Old 02-02-2010, 08:06 PM
khamul02's Avatar
all the way!
Tom Hutchinson
Old 02-02-2010, 08:19 PM
crustychief's Avatar
Do you have a toyota gas pedal? Just kidding. Maybe the linkage on the throttle body is gummed up and hanging? Or the sensor plate?
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 02-02-2010, 08:20 PM
Wer bremst verliert
JohnJL's Avatar
Try this procedure...
1. Unhook the linkage at the throttle body and manually move the throttle body open all the way. Does it stick? If not...
2. Manually push/pull the linkage to the throttle. Does it stick? If so...
3. Leave the linkage off the throttle body and get under the car. Disconnect the rearward linkage from the pivot on the transmission. Which side sticks, the throttle pedal side or the engine side?...keep moving forward until you narrow it down.
You definately want to fix this. I had a throttle stick going into a hairpin at the track and it is an experience I'll never forget.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 02-02-2010, 08:24 PM
khamul02's Avatar
I know... I thought the same thing about Toyota.. It is very strange and out of nowhere. Since I knew it would sit for a while I even put some seafoam in the last fill up.
Tom Hutchinson
Old 02-02-2010, 08:25 PM
Make Bruins Great Again
Por_sha911's Avatar
Cruise control?
Joe
khamul02's Avatar
Thanks John. That will be my plan of attack tomorrow.
Joe, My cruise control hasn't worked in years.
Tom Hutchinson
Old 02-02-2010, 08:29 PM
steely's Avatar
Not sure about your year, but my 87 has a bell crank on the engine deck - and one of 2 springs had broken - you might want to check that too if the configuration is similar. I didn't get hi-revs, but the pedal return as weak.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 02-02-2010, 08:45 PM
Jtilden's Avatar
I JUST had the SAME issue with my 80 SC....here is what I did...after checking all the usual suspects mentioned above (that did not fix the problem), I finally took the pedal cluster apart. That is where I found my problem...the accelorator bushings had totally broke apart and were causing my pedal shaft to bind. I ordered both the brass and the OEM bushings. Once they arrived I decided to go with the brass bushings because i figured the brass would not fall apart in 30 years....
95 993 Cab
99 996 C2
80 911SC Targa
85 944 N/A(sold)
Old 02-02-2010, 09:05 PM
WHCJr72S's Avatar
a leaking master brake cylinder on a nonpower brake car will cause the pedel shaft bushings to swell. The swelling will cause the shaft to stick in the bushings.
Bill Cilker, Jr.
911S Registery #98, R Gruppe #272
1972 911S
1931 Model A Ford
Old 02-02-2010, 10:12 PM
Northern Motorhead
wildcat077's Avatar
I had the pedal stick a few times as well on my 89 Coupe,although not at full throttle...
Turns out it was the bushing in the throttle linkage where it is attached to the transmission under the car.That is an area exposed to heat and road grime and needs to be lubricated and cleaned at times.
Solved the problem for me !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 02-03-2010, 02:05 AM
just me
paulgtr's Avatar
maybe there is another issue to worry about here. if it revved way beyond redline there could be some internal damamge
Old 02-03-2010, 02:32 AM
One other thing to check is the cruise control cable. It can bind up the throttle linkage and cause the symtoms you describe.
Old 02-03-2010, 04:56 AM
kodioneill's Avatar
This is the most likely the problem. The cruise cable attachment point will break and when you go wot the cable pops out and hangs up the throttle.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 02-03-2010, 05:40 AM
abit off center
cgarr's Avatar
You might also check the peddle cluster clutch and throttle arms where the cables attach. My clutch arm was bent just a tad and the throttle arm would snag on it when going to WOT. The two are very close to each other.
EDIT: I see you said it still does it even when you push in the clutch so this may not be the problem?
______________________
Craig
G2Performance
Old 02-03-2010, 06:05 AM
bdisco's Avatar
Location: Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
O noes! Not Porsche too!
'88 Carrera
Old 02-03-2010, 06:37 AM
schoward's Avatar
Don't disregard this bit of advice - I have seen the above mentioned many times - even among local folk with SCs - not just here on Pelican. Check it.
Old 02-03-2010, 06:43 AM
Originally Posted by khamul02 View Post
Thanks John.
Sometimes a faulty electronic cruise control box leads to trouble by cycling on/off, up/down without warning.
It's your call, but you should consider either fixing it right or removing the complete system including cable and servo.
1987 Carrera 3.2
Old 02-03-2010, 07:32 AM
khamul02's Avatar
Thanks everyone for all of the insight. I'm on it ... ALL. Just another handful of projects to attend to
Tom Hutchinson
Old 02-03-2010, 08:32 AM
