-   -   Help!! I lost my headlights and turn signals (http://forums.pelicanparts.com/porsche-911-technical-forum/342208-help-i-lost-my-headlights-turn-signals.html)
JeffreyNMemphis 04-19-2007 08:30 PM
Hello Pelicans,
Today I was messing with the wiring under the dash, trying to clean up wires that were just hanging or snipped off. Somehow I lost my turn signals and headlights (though I have high beams). I have running lights front and rear. I checked the fuse panel in the luggage compartment; all the fuses look ok.
Could I have knocked a relay loose? What should I be looking for? What could possibly be wrong?
scottb 04-19-2007 08:34 PM
There are a bunch of wires that run from the turn signal/high beam switch to the back of the headlight switch. Check to see if you accidentally pulled any of them off the back of the headlight switch.
JeffreyNMemphis 04-20-2007 05:38 AM
Scott,
Cha-Ching! You are the man! It was a wire plug that was loose.
THANK YOU!!!
JeffreyNMemphis 04-20-2007 05:53 AM
I still don't have fog lights operating.. the plug is harder to get at to check if it is in all the way. But that is a luxury compared to headlights and turn signals.
Jeff 04-20-2007 06:49 AM
Jeffrey, Just in case you don't know, Your headlights have to be on and in the low beam position for the fog lights to work.
scottb 04-20-2007 07:06 AM
I'm glad it worked out. Congrats!
JeffreyNMemphis 04-20-2007 07:26 AM
CU L8r,
That was the easiest repair ever! It works! <smile>
Thank you!
Jeff 04-20-2007 07:31 AM
Cool!
