Regis turd ab user
Shock Hardware
For '71 911: Do new rear Bilstein HDs come with lower bolts and washers?
Negative. You should be able to find new ones at a local hardware store with the correct pitch. I found them locally for about 6 bucks each vs 12 ea OEM.
Tony G 2000 Boxster S |
Alii&Maui
1982 SC Coupe SCWDP#0087 KCSSL#0082 |
check to be sure they are not a high-strength bolt...
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
Why would you not want a high-strength bolt for shock mounting?
sorry - I meant to check and see if the originals are high-strength -- if so, then get that, not a hardware store one
I concur. Grade 5 ~ Grade 8 SAE (not sure what the equivalent metric grades would be).
the rough eql. to a US Grade 8 is 10.9 or 12.9
I saw a chart recently but couldn't find it again when I went to post it. could prob. pull one up on Google.
