New headliner, how replace interior lights?
The first time I replaced my headliner, about three years ago, I cut small holes for the interior lights above the doors, replaced the lights, and the headliner soon pulled around the lights, leaving ugly holes. Tried to glue them back, didn't work.
Now that I have all the glass out to replace it with Lexan, I'm doing the headliner again--hated that barf beige anyway and am re-doing it in black.
Question: is there a trick to replacing the interior lights to avoid my original problem? I'm guessing that I should cut very small holes for the lights and push the lights into place, trapping the edges of the headliner in the edges of the holes in the bodywork steel into which the light units fit.
Wayne's 101-Projects book says something about "making sure the lamp is not accidentally insulated by a flap of headliner." My method would, of course, insulate the lamp unit entirely around its periphery, but I believe Wayne is wrong: at least on an '83 SC, the lamp unit has discrete power and ground wires, so any insulation of the lamp body itself would be irrelevant.
Any suggestions?
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 04-22-2007, 06:46 AM
Designer King
Paulporsche's Avatar
Wayne may be referring to THERMAL insulating. In other words, creating a barrier for heat from the bulb to escape upwards.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 04-22-2007, 07:59 AM
I have noticed on one of my cars that the hole for the interior light is actually an "X" cut across the opening. If you use a razor blade and carefully cut an "X" and extend it just short of the corners of the opening, that may give you the necessary material to pinch with the light and will not show a cut. This should work if you have the power and ground wires.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 04-22-2007, 08:28 AM
If it is wired like my 69 the ground wire should be switched ground(brown/white). Power is on all the time(black on my car) but when the door is opened and the door switch is grounded the circuit is complete and the interior lights come on. If the metal case is not grounded to the car somewhere, when you rock the interior light to be on with the doors closed there is no ground and the light will not come on. The x method above is what I used to cut my headliner but I left an area to make sure the case is grounded to the car. Hope this helps and is clear as at least mud.
Jim
69 911 2.3Ez
85 928S
Old 04-22-2007, 08:48 AM
The X makes perfect sense.
Stephan Wilkinson
Old 04-22-2007, 11:39 AM
joefrantz's Avatar
Here is the factory X.
Notice the perimeter outline of the light.
Joe
Joe Frantz
73 911 T
Old 04-22-2007, 12:17 PM
Mine was the same way. just cut enough to push the housing in and your all set.
Silver 1980SC Euro coupe
Old 04-22-2007, 01:09 PM
X-cellent.
Stephan Wilkinson
Old 04-22-2007, 01:36 PM
rgrimm's Avatar
Re: New headliner, how replace interior lights?
Wayne's talking about the early cars. If you look at the photo a few posts up, you can see the small hole in the headliner to complete the electrical circuit.
But, yup, X it is...
Roger
1968 sand beige 911 Normale coupe #11830091
1984 metallic moss green with champagne interior 911 Carrera coupe
2012 silver with red interior Boxster
Old 04-22-2007, 02:51 PM
