Send a message via AIM to EPorsche
Need some help w/pic
I've have an adapter that looks like it goes in between the cdi box and harness of the 3.0 I'm building. Does anyone one what it connects too? I'm thinking it goes to an after market cdi, but I don't know which one.
'77 911S w/'81 3.0/MegaSquirt/MSD
'81 911SC stock
Old 04-20-2007, 04:16 AM
Bump
'81 911SC stock
Old 04-20-2007, 05:44 AM
bump
'81 911SC stock
Old 04-20-2007, 09:25 AM
rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
Just took a look at my 81 SC. The black rubber connecter goes to the CDI, but there is no connector like the white one on the other end. It just goes into a bundle ogf wires that end up by the rear fuse box.
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 04-20-2007, 10:59 AM
This doesn't answer your question about what CD box the wires go to - but it might help trace the wires themselves.
Help ID wires for 6 pin CD connector
Rex
1975 911s and 2012 Range Rover Sport HSE
1995 BMW R1100RS, 1948 Harley FL
Old 04-20-2007, 11:15 AM
rs6er,
I thought the CS cdi was six pin? The black connector has eight pins. I think they had another cdi box and this is the adapter that goes between the harness and the other cdi box. What do you think? I wish I knew what it fit.
'81 911SC stock
Old 04-20-2007, 12:46 PM
rs6er's Avatar
You are correct. I just checked and it is 6-pin.
John
Old 04-20-2007, 01:10 PM
