ericwitte's Avatar
Send a message via AIM to ericwitte Send a message via Yahoo to ericwitte
clutch cable advice? 3.2 into 72 conversion
which year clutch cable should I be using? 72 pedal box and 86 915 trans...any other issues when installing the later engine into the 72? thanks!
996 Coupe, 84 Euro Carrera, Cayenne S, BMW CS 30, 72 2002 Ti (gone)
72 911 Hot Rod, Healey 100M, Giulia 1300 Ti, Merc 280SE4.5
Colorado Grand 03-04-05-07-08-11-17-18 Tour Auto 04-05
RG #650
Old 05-08-2006, 03:10 PM
ericwitte's Avatar
bump
RG #650
Old 05-08-2006, 07:27 PM
78-911SC's Avatar
I'm using the clutch cable w/hook. 930-423-401-05. I have a 3.2 going into a 70T. You should have no problem connecting to the 72 pedal box.
PJ
78 911sc Targa
70 911T
Old 05-08-2006, 09:31 PM
ericwitte's Avatar
do you have to modify the ssi's to clear the clutch helper spring?
RG #650
Old 04-23-2007, 05:30 PM
Friend of Warren
Depends on what SSI's you have. The ones made for the 3.2 have an indentation so the helper spring will clear. Not sure if the early 911 SSI's are the same in that area.
Kurt V
Old 04-23-2007, 06:51 PM
