-   -   3.2 compression test technique (http://forums.pelicanparts.com/porsche-911-technical-forum/342481-3-2-compression-test-technique.html)
DavidPorter 04-21-2007 03:30 PM
I am new to this car and didn't find specific information in a search. Where is the fuel pump relay or other suitable place to disable the fuel pump? Can I just disconnect the coil or should I ground the HT lead?
Thanks.
turbo6bar 04-21-2007 03:34 PM
Can't help you with the specifics to the 3.2, but in the Bentley manual for SCs, you remove the fuel pump relay (front fuse block, closest to driver's seat), and unplug the connector to the CDI box.
hcoles 04-21-2007 03:37 PM
I think if you pull the DME relay from under the drivers seat it will stop fuel flow... there may also be a fuel pump relay or fuse..
also I've seen mention on this site to take the readings with the engine warm
-h
2.7RACER 04-21-2007 04:51 PM
To disable the fuel pump, remove fuse #3. Pulling the DME relay also works, although the fuse is simpler to access.
Rot 911 04-21-2007 06:45 PM
Better off pulling the DME relay. Kills the fuel pump and the spark. The relay is under the driver's seat right next to the DME and held down by I think either an 8mm or 10 nut. You don't have to remove the seat, just slide it all the way back.
