-   -   Running on 5 cylinders (http://forums.pelicanparts.com/porsche-911-technical-forum/342499-running-5-cylinders.html)
1980 911 sc 04-23-2007 07:49 PM
pull a plug then try to start the car. shut off car. rinse and repeat. if it is a spark issue you may be able to notice a different idle. Another option would be to get/make a spare wire and swap till it is running smooth...
john walker's workshop 04-23-2007 08:31 PM
pulling wires one at a time is the fastest way. the dead hole will show up right away. so what if you get a tiny tingle, it ain't gonna kill ya. bunch of wimps. MSD on the other hand might. another way is to loosen each fuel line bolt or nut one at a time up on the fuel distributor. minor fuel wetness, not much, and you only need to do it for a second or two. keep a rag handy. 3.2s are easiest. just unplug one injector at a time.
T77911S 04-24-2007 05:32 AM
[QUOTE]Originally posted by rs6er
[B]
Originally posted by Paulporsche
One check you might try is to idle the engine. Have someone hold the throttle slightly open if you need to. Pull each plug wire off in turn. If you are indeed running on 5, the "bad" one is shown when the engine does not change when the plug is pulled.
Safety question: Is it safe to pull and plug these in with the motor running?
you will only do it once!:D
Gunter 04-24-2007 06:04 AM
Tiny tingle? :D
BTDT. Not recommended if you have a pace maker.
It's especially good when you lean in deep to do #3 & 6 and touch ground :rolleyes:
John: Loosen the fuel line at the FD?
Is that for when you suspect air in the line?? Or??
john walker's workshop 04-24-2007 09:09 AM
no. it kills the cylinder just like pulling a plug wire.
rs6er 05-02-2007 05:52 PM
Follow Up to my original post.
So after checking, plugs, wires, vacuum lines, distributor, etc. the problem turned out to be a faulty Oxygen sensor which was causing the motor to run way too lean. I never looked at this since my sensor probably has 500 miles on it. I replaced the old one it last summer. Thanks to Dan Jacobs for solving the mystery.
