dazed and confused
Removed both footwell boards for a cleaning and found a clear plastic tube sticking out of the clutch pedal slot; traced it back to the passenger's footwell where it entered the intake for the evaporator (no mesh grille BTW) but was not connected to anything. Have searched this forum without finding anything plus nothing shows on the exploded views of clutch pedal cluster or evaporator assembly. Any ideas?
BTW, any ideas on what the cut wire harness might be? PO hasn't a clue; maybe the remnants of the Clifford that was yanked before I bought it?
89 Carrera 3.2 Targa 2011 BMW 335d 2013 BMW X3 3.5 80 911 SC Weissach Coupe (Sold)
Designer King
Just guessing here: does condensate come from the evaporator?
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
dazed and confused
A/C hasn't worked since I bought the car last fall...I'm in the process of putting it right. I would imagine condensate does flow from the evaporator, but would expect it to drain directly below the smuggler's box through the tub...not all over the pedal cluster! Again, I don't see a drain in the evaporator assembly in any of the exploded views to determine if and where there may be a drain. From the photos I posted, this clear plastic tube is tiewrapped to other cables & leads...looks factory, non?
Back in New England!
CAn you contact the previous-previous owner, her or she might know...
-Matt
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip! |
What ever the hose was installed for, it is not "factory" and has nothing to do with the A/C. Evaporator drain is in the bottom of the evaporator housing. I would just pull it out and trash it.
Can't help with the wires but aftermarket alarm is a good guess. Where do they go? Good Luck Andrew
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires '86 944NA, Sunroof Delete, Track Rat, Full Cage '72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic Last edited by aj88cab; 04-23-2007 at 11:44 AM.. |
19 years and 17k posts...
Be sure you completely remove the old aftermarket alarm as they can cause all kinds of problems, at least mine did!
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
my guess is that was some sort of mickey-mouse modification for a drain, using the evaporator box as an outlet. Someone must have been trying to connect a drain for brake fluid or clutch fluid. Hopefully not gas.
