MFORCE
Creaking heavy clutch pedal
I removed the floorboard and tried to lube the pedal cluster but my clutch pedal is still creaking and moaning ^*&%^%&!
Is there any other area I can try to grease or lube before I have to remove the entire pedal cluster? Thank for any help
1985 3.2 Carrera Turbo Targa |
are you sure the problem is there and not in the transmission? Could it be the throw out bearing?
Tony G 2000 Boxster S |
MFORCE
not sure, it sure feels and sounds like it is right at the pedal....
any vibration?
Chris the more i learn, the less i know |
MFORCE
nope, all seems good except that darn creak.....spray lubed the whole assembly...buy still there
forget the spray stuff. when you get a copy of 101 turn to page 113.
since you're in an area where the roads are salt, poke around for rust.
MFORCE
there was definaltey rust, just looking for options so I don't have to remove the assemebly...to nice out to have it laid up in garage
shoulda started sooner.
besides we still have a bad weekend left, isn't hershey coming?
Cluster likely needs to come out for bushing replacement; don't wait too long or you might wear through to the shaft or bushing housing requiring part replacement or repair.
MFORCE
shoulda woulda coulda
it's cool, gather the parts needed and wait for that weekend, i bet the afternoon is nice.
MFORCE
figured that, just hoping for another answer....Pelican Rocks
thanks all!
