E Cams, T Heads, S Pistons?
I just picked up a set of 2.4S P/C and now I am thinking I might just put some parts I have collected onto my 2.4T EFI project motor before installing it for the summer. This is basically a temporary setup to prove the EFI concept before I build a wild 2.7 next winter.
So what I would have is:
Set of 2.4 T Heads
Set of 2.4E mfi Cams
Set of 2.4S P/C
On a 2.4 Crank.
Think it will all work together?
I think Drivability should be excellent with the higher compression and the E Cams. And that my Red-line will be a bit flow limited by the Heads. although I could always open them up a bit if required.
Robert
Currently Porsche less (but the wife has 2)
Old 04-24-2007, 10:34 AM
dtw dtw is offline
GAFB
Depending on the specific T heads you have, your intake ports may be as small as 29mm (mine were). That's going to choke off a lot of the fun-factor of your 8.5:1 compression pistons and warmer cams. In my 2.4T, I am running 9.8:1 compression and hotter cams, and opened my ports up to 34mm. Free breathing to 6200 rpm, which is where my cams run out of breath. A modest port job will be well worth the money.
Several BMWs
Old 04-24-2007, 10:43 AM
Home of the Whopper
I ran that exact engine with MFI. So far it's been my favorite engine. Pulls strong from idle to redline, easy to drive around town or at the track.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
