-   -   930 Trailing Arm Retrofit (http://forums.pelicanparts.com/porsche-911-technical-forum/343064-930-trailing-arm-retrofit.html)
North Coast Cab 04-24-2007 04:38 PM
What exactly needs to be changed to retrofit 930 rear trailing arms to a 911?
Torsion Camber Box?
Axles?
Stub Axles?
Rotors?
Thanks, John
abisel 04-25-2007 08:26 AM
Re: 930 Trailing Arm Retrofit
Torsion Camber Box?
Axles?
Stub Axles?
Rotors?
Thanks, John
Yes.
Yes.
Yes.
Yes.
I am putting '86 930 arms and brakes on my '73. I replaced the torsion bar tube with that for an '86 930. Then everything else just stands to reason. With the big 930 calipers, you may have to go with the 23mm master cylinder.
