-   -   custom shock question (http://forums.pelicanparts.com/porsche-911-technical-forum/343165-custom-shock-question.html)
edbaus 04-25-2007 08:19 AM
I am looking to adjust my rear shocks on my racing 911.
Using the shocks that are on it, I need to add a spacer to one end of the shock rod.
The question I have is, how much shock travel should I use for bump and how much for rebound.
Lets say the shock travel is 4", do I want to set up the static position of the shocks so that the rod is compressed 2", or about in the middle of the travel, or should I have it set up so that it compresses less staticly so that there is more travel under compression.
Ed
jaydubya 04-25-2007 08:36 AM
Hi Ed - ideally you would want at least 2" in both bump and rebound for a track car.
Also most shocks are designed to work most effectively when displaced about the center of the piston travel.
