Johnb911's Avatar
Which Brake Fluid
I have read here and there and don't really know what fluid I am supposed to use.
No track use.
Weekend Car.
What do I buy and how much if I want to purge the system?
Help.
JOHN
79 EURO SC
"24 Years Later - The Dream Came True"
Old 03-26-2007, 02:23 PM
Oh Haha's Avatar
Use ATE Blue or Gold. For cars that sit, this fluid is not so apt to collect moisture. Plus,you can see when you have all of the old stuff out.
1 quart/pint, whatever Pelican sells is enough for a complete flush.
Pacific Blue
Wayne
Old 03-26-2007, 02:32 PM
Johnb911's Avatar
JOHN
79 EURO SC
Old 03-26-2007, 02:42 PM
randywebb's Avatar
and alternate the colors when you change it every 2 years
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 03-26-2007, 05:19 PM
msk1986911's Avatar
What's the basis for changing the fluid every two years? The Bentley manual specifies every year. Aren't more modern fluids less prone to collect moisture (which I assume is the primary reason for the need to change the fluid)?
Old 04-26-2007, 07:48 PM
randywebb's Avatar
Porsche specs 2. Yes, 4-200 is less prone to boil with moisture conc.
A prev. thread had some graphs posted if you search.
Some street drivers do it every 3 yrs.; some racers do it every few races - depends on usage & environment.
Can always get it tested if paranoid, but why bother - just change it.
Old 04-26-2007, 08:52 PM
If you want your calipers and master cylinder to last as long as possible, change that fluid annually.
The vast majority of brake problems/corrosion in brake systems is due to accumulated moisture that could have been avoided with regular fluid changes.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 04-27-2007, 12:21 AM
