911 fuel lines
Is replacing the fuel lines on a 1974 911 a do it yourself project, any special tools needed, and ant pitfalls to be aware of?
Thanks.
Old 04-18-2007, 07:28 AM
Bollweevil
Re: 911 fuel lines
Thanks.
Just noticed this is your first post... welcome aboard. More information available here than you can possibly imagine.... sensory overload. And it is traditional (if not required) that you post a pic of your ride ASAP.....
Just did mine and the biggest problem I had was finding the 10MM ID fuel line that is the input line to the fuel pump. Pelican does not carry and had no source. I couldn't even google up a supplier on the internet. A local shop specializing in foreign autos was able to order some for me at $5 / ft which is outrageous but really no choice and only needed 2 ft.
Some of the lines are hard to access and you just have to do by feel but no real problem.
Also the crimped line that is input to the fuel accumulator is NLA so I dremmeled off the crimp and used a clamp.
Jack
74 911 Coupe
2.7L - K21 Option - S suspension
Old 04-18-2007, 08:17 AM
Elu Elu is offline
Elu's Avatar
Send a message via Yahoo to Elu
I did mine last fall. I got the tubing at Napa. It was a royal pain trying to work in the front at the gas tank. Reaching your hands up behind the stearing mechanism is really hard to do. And the fuel lines are not so pliable. I managed by loosening up the end of the fule line by repeatedly pressing my needle nose pliers into the opening to stretch it out a little. I managed to get it over the existing rigid lines about 3/4 of an inch and then clamped it down. The lines at the fuel pump were not as hard to put in. Simple enough, but I had some serious hand cramps afterwards.
Come check out my new stuff....you know you want to.
www.myspace.com/elu
Elu - the sensual nature of humanity
Available on Eroica Records
The new album is now available.
Old 04-18-2007, 08:33 AM
19 years and 17k posts...
azasadny's Avatar
I replaced all of my flexible fuel lines (not the fixed lines in the tunnel) a few years ago and it was tedious and tricky, but not especially difficult. It's definitely worth the effort when you see the cracked, brittle fuel lines you will be replacing! I also replaced all of the clamps with some stainless steel clamps from McMaster-Carr. Good luck!
Art Zasadny
Learning the bass guitar
www.ford.com
Old 04-18-2007, 10:00 AM
76 Targa's Avatar
I just did most of my rubber flexible fuel lines after a minor blowout that left me stranded about 5 miles from home. The tough part is getting in above the transmission mounting bracket. It takes real patience and many bloody knuckles. I was able to replace the large diameter hose going from the tank to the fuel pump up front, but didn't know what to do with the other two crimped hoses. Suggestions? Thanks!
76 911S Targa Widebody, 61 VW Bus, 2012 Fiat 500S
Old 04-28-2007, 04:05 PM
