toddu's Avatar
Smugglers box - white wire????
While removing some of the AC components (basically just the blower) from the smugglers box so I could get to the steering coupler, a white wire popped out of the blower housing (which sits on top of the condensor). The wire almost looks like it's a temp sensor, not like it was actually connected to anything. I'll try to get a pic when I return to town end of the week.
Anyone know off hand what this is, and where I should stick it (ok, all the smart comments already went through my head!!!).
Thanks,
'81 SC
Old 05-01-2007, 05:33 AM
Barrpete's Avatar
It's a temperature sensor and it slides into a tube in the evaporator coil. I believe it functions by sensing changes in air pressure. If you still plan on using your AC don't cut it or kink it.
1986 Carrera Coupe
1999 Chevy Tahoe
1987 Chevy Blazer
1955 Chevy Apache 3100 Pickup
"A little knowledge is a dangerous thing"
Old 05-01-2007, 06:40 AM
toddu's Avatar
Ah, super. I was thinking looking for a place on the blower housing to stick it. I'll look on the condensor itself then.
Thanks man!!
'81 SC
Old 05-01-2007, 07:00 AM
Barrpete's Avatar
There is a hole on top of the evap/blower housing that it will slide into.
1986 Carrera Coupe
1999 Chevy Tahoe
1987 Chevy Blazer
Old 05-01-2007, 07:14 AM
