1985 911 Horn Stuck when key on
I've read through a bunch of posts about stuck horns but none seem to match what my car is doing.
1. ignition off -- horn works normal from steering wheel - I can hear both horns 2. ignition on - horn is stuck on - but only 1 horn 3. ignition on - all fuses and relay removed - horn stuck on any other way to just disconnect the horn until I can figure it out? Thanks AO Last edited by agentogden; 04-30-2024 at 10:38 AM.. |
further inspection -- I disconnected the horns completely. its like it is the alarm horn. this car doesnt have an alarm system - but I guess has the horn and wiring.
how to disconnect the alarm horn? |
Tags |
1985 , horn , relay , stuck |
