der Mond's Avatar
Help - unusual gauge activity with hesitation
The '87 Carrera was running perfect in the fall. After re-start it ran perfect initially, then the gas gauge started wavering, then the tach needle began strangely zeroing as soon as I lifted throttle, them wavering widely. At first the only unusual run problem was a hesitation at 4500 rpm, then the rough running and bucking eventually came and went at any point in the rev range, and more frequently. Any ideas?
Peace & Thanks,
der Mond
'87 Carrera Coupe
Venetian Blue Metallic
Old 04-26-2007, 08:48 AM
The gas gage system is pretty stand alone and isolated from the engine controls so your gas gage problems are probably coincidental.
The tach indications going away could be a big clue to your running problems. Are you a purist or a parts shotgunner? You will get 15 replace the DME relay replies and that part could well be suspect.
Old 04-26-2007, 09:02 AM
der Mond's Avatar
Exclamation Help!
I put my spare DME relay in - no change. My alternator reads steady 13.7 - 13.8 at idle, and rock-steady 13.86 from 2500 on up. When I go WOT to 4500 rpm it bucks like a bronco, and the tach wavers wildly upon deceleration. Then the tach continues to zero and waver every time I decelerate. I'm a long way from a Porsche mechanic, guys, please help!
Peace & Thanks,
der Mond
'87 Carrera Coupe
Old 04-29-2007, 01:49 PM
