-   -   Another Thread On Replacing Targa Seals... (http://forums.pelicanparts.com/porsche-911-technical-forum/343752-another-thread-replacing-targa-seals.html)
rcecale 04-28-2007 06:28 PM
In anticipation of ordering one of Dan Petchel's (carsinc) new Targa-Windshield screen, when they become available, I've started replacing some of the other seals in an attempt to "waterproof" the cabin...as much as I can.
Here are some shots of the old Targa Bar Seal as it was coming off. From the condition of the seal and the adhesive, it's no wonder there was some searious leakage going on.
These first couple of pics show the seal as it was coming off in my hand...no tools or acetone applied or anything...it just came right off in my fingers... :eek:
http://forums.pelicanparts.com/uploa...1177809669.jpg
http://forums.pelicanparts.com/uploa...1177809700.jpg
http://forums.pelicanparts.com/uploa...1177809714.jpg
These next pics show some of the "Jim-Rigging" the PO did...painting over the adhesive, and WTF is with these bolts?
http://forums.pelicanparts.com/uploa...1177810020.jpg
http://forums.pelicanparts.com/uploa...1177810037.jpg
http://forums.pelicanparts.com/uploa...1177810053.jpg
http://forums.pelicanparts.com/uploa...1177810070.jpg
http://forums.pelicanparts.com/uploa...1177810084.jpg
http://forums.pelicanparts.com/uploa...1177810101.jpg
Randy
1982911SCTarga 04-28-2007 06:36 PM
Randy, those bolts should be plastic trim screws that act merely to cover the attachment points for the ski rack. They're not structural. Kind of a poor substitution on the part of the previous owner.
Brian
rcecale 04-28-2007 06:41 PM
Here are a few shots from the other side of the car. What a mess!!!
http://forums.pelicanparts.com/uploa...1177810404.jpg
http://forums.pelicanparts.com/uploa...1177810417.jpg http://forums.pelicanparts.com/uploa...1177810434.jpg
In one of the threads I read, someone suggested that since the seals were removed, this would be a great opportunity to clean up the Targa Bar Cover. Simply remove the screws holding it in place and voila!
I was wondering if someone would be so kind as to photoshop a stainless steel Targa Bar onto this pic of my car, just to give me an idea...
http://www.pelicanparts.com/pmpre/im...e/MVC-011S.JPG
While I'm on the topic of the Targa Bar, I noticed there are several locations for screws to fasten the cover. On mine, I found a total of 6 screws holding mine on...three on each side, and none across the top. Also, the holes were no-where near being lined up for installing screws, I'll post pics tomorrow...
Randy
rcecale 04-28-2007 06:44 PM
Brian
Thanks, Brian! I was hoping they weren't important. I found the plastic ones on the other side. When I went to remove them, they all but disintegrated under the twising of the screwdriver. they actually looked more like plastice set-screws.
Randy
Dan in Pasadena 04-28-2007 06:47 PM
I don't have a Targa, but I am curious for far you're gonna take the cleanup before installing new? 3M Trim Adhesive Remover? I have some crap like that on the edge of where my sunroof felt SHOULD be, but isn't. I have been putting off doing the cleanup as I am afraid I'll be peeling paint off. Then I think, "Well, if it comes off with trim adhesive remove then maybe it SHOULD come off, so I can mask, primer, paint and let it all cure before trying to adhere new good stuff to old crappy stuff". Post what you decide to do and what works.
tcar 04-28-2007 06:51 PM
What size are your wheels? They look small.
With all the mods to the car, I'm not sure an SS targa bar would look that good.
rcecale 04-28-2007 07:01 PM
Dan,
I actually used straight acetone to clean off the old ahesive. It was a little too dark outside when I finished to get any good pics, so I'll get some tomorrow. The acetone did a nice job on the adhesive without doing a thing to the paint.
Tcar,
The wheels are 7.5x17 in front and 8x17 in the rear. I agree the rears look a bit small, but if I went any larger, I'd have to raise the rear end.
Randy
rcecale 04-28-2007 08:33 PM
Another question...
I've read a few different opinions regarding where to apply the adhesive. One said to only apply to the bottom (side B in this pic). A few others said to come up the sides a bit (A and C in the pic). Looking at the location of the adhesive on my car, it appears the PO applied it as far up as side D.
What are your thoughts?
Randy
rcecale 04-29-2007 05:43 AM
I suppose it would help if I posted the pic I referenced... :D
http://forums.pelicanparts.com/uploa...1177850556.jpg
Randy
Scott at Pelican Parts 04-29-2007 07:26 AM
Randy,
I replaced my front targa bar seal a few weekends ago and I used adhesive on faces A, B, and C (and probably some D -- I don't recall for sure, but I used glue in the entire channel). Heaviest on B, and lighter on A and C so it wouldn't seep up and make a mess.
rcecale 04-29-2007 01:01 PM
Thanks, Scott! That's how I was thinking, but since I also saw it posted here to only apply the adhesive to B, I figured it wouldn't hurt to ask.
A, B and C it shall be. :D
Randy
kach22i 04-29-2007 01:10 PM
Will all the plastic nipples now be avaliable too?
