-   -   Carrera alternator in an SC??? (http://forums.pelicanparts.com/porsche-911-technical-forum/343923-carrera-alternator-sc.html)
m_wuebben 04-29-2007 06:46 PM
I took my alternator out to have it tested. The auto parts store in my town said they couldn't test it, so I decided to see how much a replacement would be. Got the number off the back (Paris Rhone 911 603 120 05) and when I searched for it on this site, I got this: Alternator, New, 911/911 Turbo (1984-89), excludes 1989 C4. Now how do I tell if I have to do the regulator move or not?? Thanks, Mike.
m_wuebben 04-30-2007 06:14 AM
Can anyone help?
john walker's workshop 04-30-2007 06:29 AM
your '81 would not have the longer 90A unit that carreras use. to use it, a carrera fan housing would be needed, or have yours machined deeper. '81 is still external regulator, carrera is internal. not a big deal. just remove the 81 regulator and don't use the black wire that used to go to the brush pack on the '81.
m_wuebben 04-30-2007 08:53 AM
Thanks for the help, again. I used a lot of you help to do my trans. Cheer, Mike.
jmohn 04-30-2007 09:09 AM
If you do use the newer internally regulated alternator, I think you'll also need a small resistor (I don't know the proper value) wired in parallel with your alternator idiot light to assist in "exciting" the Carrera alternator.
Jerry M
'78 SC
304065 04-30-2007 09:10 AM
Search here under "zero-ampere RPM" and "early_s_man" to learn all about that resistor.
