Montana 911
k9handler's Avatar
Send a message via Yahoo to k9handler
M&K Muffler for 993 - Sound Clip
I finally had a chance to have the dual-in / single-out M&K Muffler installed on my 3.6 engined 1975 911S. Let me start with a simple statement...I love the sound!
The fit had to be adjusted since this is one of the test designs.
The Major adjustment was to add 2" of pipe to the drivers side flange, this pushes the muffler to the rear and straight with the rear bumper.
The second adjustment was a cosmetic change, the exhaust tip was rotated up to point out the rear of the car instead of down toward the ground.
Here are a few images of the muffler installed.
To compare the sound I have compiled a small video clip.
M&K993
Thank you Ben for the great muffler!
H.D. Smith
2009 997.2 S 3.8 PDK
2019 Ford Ranger Lariat FX4 Baby Raptor
2019 Can Am Renegade 1000R XC
2020 Yamaha YFZ450R
Old 06-12-2006, 10:55 AM
Me like track days
Craig 930 RS's Avatar
Sounds like a V8!
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 06-12-2006, 11:02 AM
Montana 911
k9handler's Avatar
you think? I thought the old setup of just cats and tips sounded very V-8'ish but the M&K has brought back a true Porsche sound. =o)
H.D. Smith
2020 Yamaha YFZ450R
Old 06-12-2006, 11:09 AM
stormmaster's Avatar
Send a message via AIM to stormmaster Send a message via Yahoo to stormmaster
I think it sound much more Porsche-like
Don Booth
87 Carrera Coupe (Current)
70 911 T Coupe
74 914
Old 06-12-2006, 11:15 AM
smitty,
any thoughts on the db reduction? any resonance at all?
-bernie
Old 06-12-2006, 11:19 AM
Montana 911
k9handler's Avatar
the sound is great and a drive at 3k to 4k rpm was very nice with very little resonance. This is a sport design muffler so it's not super quiet, my guess is well under 100 db at 3500 rpm and not much louder at 6k rpm. =o)
H.D. Smith
2020 Yamaha YFZ450R
Old 06-12-2006, 11:48 AM
Any chance you can get that clip in some other format ? My mac does'nt read wmv
Pleeeaaase ...... me wanna see.
Old 06-12-2006, 12:02 PM
DG624's Avatar
It would be nice to compare with the original equipment muffler...it does sound quieter. The first muffler was too boomy and would be to resonate driving without ear plugs. How about the differencce in power or weight, how does the twin outlet compare?
Old 06-12-2006, 12:12 PM
rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
Download Windows media Player for free. You can play it on your mac. I did.
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 06-13-2006, 04:39 PM
herman and rs6er-
Download the free Flip4Mac plugin and view WMV files inside of QuickTime--a much more pleasant experience than that crappy Microsoft player.
http://www.flip4mac.com/wmv_download.htm
-Terry
Old 06-13-2006, 08:31 PM
Montana 911
k9handler's Avatar
also the M&K is soooo much lighter than the stock system. The butt dyno tells me that there is more back pressure and possibly expanded the power band slightly, it feels like it kicks in at 2k rpm instead of 3k.
H.D. Smith
2020 Yamaha YFZ450R
Old 06-13-2006, 09:19 PM
Montana 911
k9handler's Avatar
here are the numbers:
idle - 800 rpm - 88 db
mid - 3500 rpm - 99 db
high - 5000 rpm - 107 db
this is a good thing as under 100 db at the mid range will get me back on the Nurburgring.
H.D. Smith
2020 Yamaha YFZ450R
Old 06-14-2006, 12:12 AM
I've got the same muffler on my 3.5 that has 993 heat exchangers and I love the sound. It really does have a V8 rumble at idle. I can't wait to hear it when I toss the CIS and install the 46mm PMOs this weekend!
Old 06-14-2006, 01:00 AM
Montana 911
k9handler's Avatar
the best I can describe the sound is much like the Yellowbird, just a bit more rumble though. Although I think the Yellowbird is 110 db at WOT.
H.D. Smith
2020 Yamaha YFZ450R
Old 06-14-2006, 01:06 AM
Can you provide any more details on what was required for the installation? Any solution for heat?
Bill Miller
81 Targa Guards Red
3.6, M&K 1 out, S4 brakes
83 ROW CAB Rubinrot Metallic (RIP)
Old 06-14-2006, 05:33 AM
Smitty, I tried to respond on gruppeb but I can't log on. Anyhow how come you extended the length 2 inches? I have a bunch guys running this muffler without mods!!!!! Well william yours needs alittle help but a bunch of other guys. All of the mufflers were fit off of my car with 993 exchangers and the dougs with the 3.6 . FEED BACK IS IMPORTANT
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 06-14-2006, 06:17 AM
Montana 911
k9handler's Avatar
Ben,
If you look at the second picture you can see that the muffler would not be in line with the rear of the vehicle and also would hit the aluminum heat tube that runs above it. The shop added the 2" to that side and that places it where it should be. Also the tip was pointed toward the ground so they re-positioned it to point straight back. When I get home I will post a picture of the parts pulled off the car that show the mounting flanges are not in line. They did a great job and I am happy with the performance. =o) Thank you for the muffler, I highly reccomend your products.
H.D. Smith
2020 Yamaha YFZ450R
Old 06-14-2006, 06:53 AM
Montana 911
k9handler's Avatar
here is the old system.
And after a bath to get all the mechanic grime off.
H.D. Smith
2020 Yamaha YFZ450R
Old 06-14-2006, 09:14 AM
what are you doing with the old system?? I might need it for fixturing
Ben
89 944,85.5 944
914-6werkshop.com
Old 06-14-2006, 09:31 AM
Originally posted by k9handler
Ben,
If you look at the second picture you can see that the muffler would not be in line with the rear of the vehicle and also would hit the aluminum heat tube that runs above it. The shop added the 2" to that side and that places it where it should be. Also the tip was pointed toward the ground so they re-positioned it to point straight back. When I get home I will post a picture of the parts pulled off the car that show the mounting flanges are not in line. They did a great job and I am happy with the performance. =o) Thank you for the muffler, I highly recommend your products.
Thanks for the feedback and the pictures.
Can you provide any more details/ measurements / pictures on the installation as well as clearance to the rear valance?
I'm really enthusiastic about this now, especially since you mentioned something about the aluminum heat tube. (Are you referring to the stock aluminum tube for the 993?) Where did you put the O2 sensor(s)?
I'm planning a 3.6 installation into my 81 SC and these are some of the last details.
I'd surely appreciate any help you can give to me and Ben!
BTW it looks great and yes Ben's mufflers are very high quality stuff!
Thanks again!
Bill Miller
81 Targa Guards Red
Old 06-14-2006, 09:40 AM
