930 ZF LSD into a 915 or 70-71 mag 901
I was wondering if it is possible to install a 930 ZF LSD's into a 70-71 mag. 901/911 type transmission?
I'm told it is pretty straight foward into a 915 just have to re-shim for proper back lash...
What I have is a... 79 ZF LSD set at 80% from the factory it was removed in 79 with only 8k miles. I guess I'd have to swap some friction discs to get it down to around 50% to be streetable...
Any input would be greatly appriciated
Old 05-03-2007, 06:15 AM
archnraft - I just sent you a PM about a possible solution
Sean
1982 SC D-Stock #372
NASA GTS2
1971T restoration in progress, read about it here:
http://911restorationmadness.blogspot.com/
Old 05-03-2007, 06:37 AM
What is req'd to install a late model 915 ZF LSD into a 70-71 mag. 901/911 type transmission?
Old 05-03-2007, 07:39 AM
