Unhappy factory alarm
Someone tried removing the Porsche factory alarm on my 87 carrera. It is located behind the blower against the firewall.
Please, Please......
Can some electrical Guru tell me if by doing this the wiring to the ignition is now faulty? Is this why my car wont start after installing a new computer and DME relay?
No spark, no power to fuel pump?
How does the factory alarm work, cant find it on the wiring diagram in the Haynes manual?
Thank you to anyone that can help.
Old 04-26-2007, 12:31 PM
defcon65's Avatar
The short answer is yes, but I don't have the wiring diagram to post it. Steve Wilkinson (sp?) mentioned this exact problem in his book, The Gold-Plated Porsche. You'll need the wiring diagram to trace and replace the circuit that has been altered. Try doing a search for it, there's quite a few threads on it.
By the way, the factory alarm IS garbage; I've set mine off any number of times. It attracts zero attention.
Regards,
Joe
85 Carrera
64 Honda Dream - for sale
71 Hodaka Super Rat - keeper
Old 04-26-2007, 12:47 PM
Thank you , I will try searching for his article or book,
dab
Old 04-26-2007, 01:40 PM
Make Bruins Great Again
Por_sha911's Avatar
Side note: in case you were thinking about it, do a search on aftermarket alarms (and all the problems people have with them) before going with one. A faulty alarm can be your worst nightmare.
Joe
Old 04-28-2007, 08:01 AM
I will never have an after market alarm, too easy to take out the fuel pump relay. Thanks for the tip and all that have helped me so far.
When I get it running, will post some pics.
Old 04-29-2007, 12:11 PM
Latest report, got hold of a wiring diagram for the 87 carerra and shows the factory alarm, will reconnect it, test it and if ok, will see if car starts,
david
Old 04-30-2007, 11:04 AM
Here's a nice link to a PP post with a nice picture of the factory alarm module & how to wire around it....84 carrera wont start
Hope it helps!
regards,
jlex.
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 04-30-2007, 01:23 PM
thanks, dab
Old 04-30-2007, 01:53 PM
