M&K ?'s
For those that have M&K mufflers, specifically 2in/out mufflers, how much and where do you see resonance in your mufflers? I am sure Ben will be able to chime in. I know I can not eliminate it but I am hoping it will be less than my GHL due to the increased muffler size over the GHL.
- Tyler 1988 911 Carrera Grand Prix White/Black 2015 Cayenne Diesel Black/ Luxor Beige/Black |
Mine is around 2000-2300 or so. I ended up purchasing one of Bens caps and I cap the passenger side outlet when I drive on the street. When I autocross,DE or just want to work off some anger I uncap the passenger side and let her rip ! When it's capped there is no resonance. In my opinion this is the perfect setup as you can control the noise/resonance with a simple 1 bolt cap.
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
I have the dual outlet version II. It has zero resonance, though it is loud. It won't wake the dead, but it is loud. It does not drone or resonate.
My dual outlet version I did drone / resonate. So he made some changes that worked, between the two versions. Doug
1971 RSR - interpretation |
Ok my set up is the ssi and 1 out on a 3.0 it does drone and resonate up to to 3000 rpm . My muffler also was blowing out fiberglass so maybe i got a reject not sure.
72 911 82 911 70 GTO ![]() 97 GT Ragtop 74/76 Jeep cj's |
My previous set-up was stock heat exchangers, cat, and a 1-in-1-out GHL....absolutely no resonance at any rpm. When I changed to SSI's and a M&K, I get a resonance at 2300 rpm. Twenty-five rpms north or south of 2300, there's no resonance. Ben offered to alleviate the situation, but I've been too busy and really don't find it that annoying at this point to make it a priority.
'82 911 SC |
Thanks for the responses fellas. I ordered my M&K this morning and will be putting the GHL up for sale on the board once the M&K comes in and is installed.
To coment on drone think about this for a second What tire diameter? what RPM range do you cruise at? What compression level do you have? What cam shaft is being used? What induction is being used? What gear ratio is being used? ALL OF THESE ARE DIRECTLY RELATED. If you "lug the engine" in some way you will get a drone of sorts. some people are more to be concerned then others. So drone is subjective to the individual. If you cruise at say 2600-3000 you will usually have no issues. Quick story. I just drove a customers car with a 3.2,ssi, and one of our earlier 2 in 1 outs. To me it was rather quiet. It sounded good , No droning could be detected just sounded pure "european " Also while my car was still NA I used a 2in 2 out on that and could hold a conversation with my son(4 at the time) in the back seat. we were not yelling or rasing our voices. So as I said it all depends on what the person wants and what they expect for noise levels.. I hope this helps
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
It does and to answer your questions:
245/45/16 rear tires around town I would say the rpm range is anywhere from 2k-3k The motor is a stock 3.0 with 40MM PMO carbs and no changes were made to gear ratios on the 915.
you currently have the 2 in 2 out ghl? Then there won't be a huge difference between the 2 except the sound quality
I do have the 2in 2out ghl however what I noticed is the difference in size of the muffler between yours and the ghl. The ghl is very small with very large tips where as yours looks to be more in size with the dansk mufflers.
yeah ours is more like the traditional 911 muffler (increased volume of exhaust gasses )
to answer though the droning is all up to the drivers habbits etc..
I guess I've probably got a V1, because my dual outlet resonates pretty badly right at 3k and a little above. Perhaps a cap or a V2 version is in order, as it's loud. What are the options if I'd like it quieter?
69 w 997 GT3 3.6L |
you can cap it very easily and it will drop down quite a bit
