Pertronix installation
Hello, I've read all of the posts but still have a couple of questions.
1. Is the best place to connect the black wire inside the distributor on the original spade plug from the points? 2. Where is the best place to connect the red wire. Did you have to extend the wire? 3. They provide a grommet to get the wire through the dizzy but there is no access hole. How do you get the wire outside the housing? Thanks, Joe |
OK never mind, I pulled the old feed through terminal block. I had to pull the dizzy before it made sense.
Joe |
| All times are GMT -8. The time now is 12:32 AM. |
