unique parts request - brake ducts (cross post)
Hello,
I have found almost everything I need on this BBS for my recently purchased 72 Targa. I might need a few more things: - The car has 85 body parts, including the lower front end with fog light holes and mounts. Currently there are no fog lights mounted and was thinking about running some kind of brake and oil ducting for cooling. Does anyone sell or fabricate something like this that would also dress up the fog light holes? - The car has a 3.2 transplant and probably needs a front oil cooler and lines. Anyone have a bolt on setup that would work (the 72 911 T did not have a front cooler or lines for one)? TIA! Scott |
bump
For the PNW you could probably be just fine with a stock Carrera cooler in the front right fender. You will also need the hard lines and thermostat in the right rear fender well.
Might be worth a consult with John Walker on exactly what you need and then go parts shopping. As far as the fog light holes go, how about actual fog lights? I hear it rains there occasionally. :D |
smart racing sells the brake cooling ducts -
how about a picture (of the front of the car) and maybe we can help you - |
| All times are GMT -8. The time now is 04:26 AM. |
