-   -   73 updating to SC trailing arms and calipers????? (http://forums.pelicanparts.com/porsche-911-technical-forum/344727-73-updating-sc-trailing-arms-calipers.html)
ezraman 05-03-2007 06:15 PM
I was told that I need the E-Brake from the later year, that my 73 stock set up wont work with the later trailing arms. Is this case?
Richard:confused:
randywebb 05-03-2007 08:38 PM
check the p/n's on PET if no one replies
I posted a bunch of what works with what a loong long looooonnnngggg time ago - doubt if you'll be able to find it on the search engine.
doubt if it is the e-breake - more likely CV joint matching
I do know you can put '77 arms on a 73.5 - I did it.
joefrantz 05-03-2007 09:24 PM
No brake issues with mine either ('76 arms into '73). E brake shoes are the same, as are the calipers. You should be able to use the stub axles from the '73 for CV compatibility. You'll need shorter 14mm lower shock bolts. THe shocks mount to the steel arms with a bolt and nut. They're threaded into the aluminum arms (no nut) and the older bolt will bottom. I think it needs to be at least 5 mm shorter, but measure to be sure.
Good luck
Joe
Ron,K 05-04-2007 06:30 AM
I found this article helping when I changed mine several years ago...
http://forums.pelicanparts.com/uploa...1178285335.jpg http://forums.pelicanparts.com/uploa...1178285349.jpg http://forums.pelicanparts.com/uploa...1178285363.jpg http://forums.pelicanparts.com/uploa...1178285374.jpg http://forums.pelicanparts.com/uploa...1178285385.jpg
911pcars 05-04-2007 03:37 PM
Downloadable PDF files here:
http://members.rennlist.org/911pcars/AlloyContrlArms.htm
Sherwood
joefrantz 05-04-2007 10:31 PM
Just remembered -- You'll need a new hard brake line from the hose to the caliper -- here's a link with pictures and part numbers.
http://forums.pelicanparts.com/showthread.php?s=&threadid=191148&perpage=20&pagen umber=1
