paslantnose's Avatar
AAR wiring info needed
Can anyone tell me the correct wiring for the AAR?
Mine has had the wires cut and removed from the engine harness.
Where do i need to connect it to in order for it to work again?
By looking at the wiring diagrams, i see that it used to draw power from a red w/white wire off of the fuel pump relay.
Ok, no big deal to connect that back.
Does this mean that whenever the fuel pump is running, the AAR has power?
If that is correct, i guess i've solved it myself BUT, i just want to be sure about this.
1980 911SC Slant Nose
Can you say MegaSquirt !
Old 06-21-2007, 05:32 PM
sudo apt-get purge 930
equality72521's Avatar
You are correct.
--clutch-monkey
Old 06-21-2007, 06:50 PM
The AAR and the WUR are powered on the same circuit. Have the WUR wires been cut also?
Old 06-22-2007, 04:10 AM
