-   -   Should I replace the battery? (http://forums.pelicanparts.com/porsche-911-technical-forum/344875-should-i-replace-battery.html)
Sam 69 Gulf 05-04-2007 03:59 PM
Car turns over fine and fast.
PPI stated 100+Amps @ 13.4V for a load test on charging system
Should I replace, I looked at the battery and couldn’t see any electricity leaking but wanted to be sure! ;)
9dreizig 05-04-2007 04:11 PM
Sounds like it's working fine to me,, why fix it if it ain't broke??
CanAmThunder 05-04-2007 06:59 PM
I'm glad you did not see electricity leaking from the battery.
Better check your turn signal fluid.
Sam 69 Gulf 05-05-2007 09:26 AM
I know
....some of the smoke is leaking out of the motor too....
