To smoke or not to smoke?
Any help would be appreciated. My 3.2 has a very erratic idle, up and down. Sometimes it will smoke like a ..and other times it doesn't. It almost allows smokes on start up, even though the engine has less then 10,000 miles on it. I can be going down the road and lots of smoke. Minutes later nothing? Help!!
Old 05-18-2007, 12:40 PM
what color smoke?
Nick
'85 Carrera
Old 05-18-2007, 12:58 PM
fanof911's Avatar
Hi
What car ?
Is your idle always erratic, I mean when cold and when warmed up ?
Fanof
911SC 83
132kmiles
Black, Turbo tail
Black leather interior
Old 05-18-2007, 01:01 PM
911, blue smoke, idle is bad when hot or cold.
1969 911, resurrected into Widebody Slantnose Cabriolet
Old 05-18-2007, 01:21 PM
fanof911's Avatar
Hi
Blue smoke can mean valve seat to be reworked.
Idle always erratic can also mean some studs broken.
Doesn't sound good at all :-(
Fanof
911SC 83
132kmiles
Black, Turbo tail
Old 05-18-2007, 01:33 PM
year?
Could be overfilled oil tank...
Nick
'85 Carrera
Old 05-18-2007, 01:59 PM
I am not sure of the year, but I did check the oil the other day and I was at the bottom of the dip stick. After I added a quart it seemed to smoke more. Are all dip sticks the same, or could I have one that's the wrong length?
Old 05-18-2007, 02:14 PM
creaturecat's Avatar
Are you checking with the car on level ground, warmed up and running ?
Old 05-18-2007, 02:25 PM
Is the car supposed to be running?? I just got it and wasn't told this!
Old 05-18-2007, 03:18 PM
There is your problem. Over filled with oil.
You need to check it when the engine is at operating temp. On level ground. fill to between the two marks on the stick.
Silver 1980SC Euro coupe
Old 05-18-2007, 03:40 PM
