SC license plate lights not working
The two small lights on either side of the license plate in the rear of my 82 SC have suddenly stopped working.
It's probably not the bulbs, since both are out(?) What's the most likely cause? The lamp covers come off with a couple of screws to replace the bulbs. Haven't done anything yet, since I don't drive it much at night. The rest of the lighting works fine.
'03 Boxster *****
'82 911SC ****
'98 BMW Z3 **
'87 300Z ***
'80 BMW 320i ****
Old 05-06-2007, 09:10 AM
Current not reaching the lamp units. I would assume, without getting out the wiring diagram, that there's a single feed to the license-plate lights that then branches to both. Since both have failed simultaneously, you've either lost a ground, had a wire lose continuity or blown a fuse. (Latter would be indicated by whatever else is on the same fuse having failed.)
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 05-06-2007, 10:14 AM
Thanks, Steve. Don't think it's a blown fuse--everything else is OK.
Could be a ground wire loose. I haven't really troubleshooted it yet. Hopefully don't have to remove the bumper.
'03 Boxster *****
'82 911SC ****
'98 BMW Z3 **
'87 300Z ***
'80 BMW 320i ****
Old 05-06-2007, 11:13 AM
Sultan of Sawzall
rouxroux's Avatar
Those housings get VERY brittle with age. When I removed the bumper pads on one of my 86's, they shattered and became dust with one tap.
Gruppe B #319
'66 Monza coupe 110/PG(white)
'95 993 cabriolet (wife's)
Old 05-06-2007, 11:29 AM
Just bought your book on Amazon.
'03 Boxster *****
'82 911SC ****
'98 BMW Z3 **
'87 300Z ***
'80 BMW 320i ****
Old 05-06-2007, 07:22 PM
Hey! I just make a buck fifty. Or maybe it's fifteen cents.
Stephan Wilkinson
Old 05-07-2007, 06:52 AM
Wash. State
nesslar's Avatar
Lightbulb
If your SC is wired like my '86, then you'll find that the left light is fed from the right light. Probably your connection at the right side is corroded/loose, therefore neither has 'tricity.
Old 05-07-2007, 08:01 AM
emac's Avatar
Hytem
I had the same issue last year. The power was found behind the left (drivers) tail light. Very easy to remove but place something on the bumper as it is real close and the chances of scratching are great. I found a broken wire as well as a loose ground.
Ernie 81 SC
Old 05-07-2007, 08:18 AM
